Timing Light help
Timing Light help
We went to set the timing on my 1988 camaro iroc-z 350 TPI and the timing bracket (plate with the numbers on it) is rusted and we cant find the 6 could I get someone to up a pic of it, its stock not aftermarket, thanks.
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
If you search, you should find a picture of it.
The "zero" is the large tooth/valley. The first peak to the left (looking at the engine from the front) is 4 degrees. The first valley to the left of that first peak is 6 degrees.
Re: Timing Light help
five7kid thanks for the feedback, I have searched google, ebay, and thirdgen.org, thing is I'm a novice and I have no idea what to seach for, but your info is what my buddy was speculating and according to what you said it would mean its is off time, it was on the 4, I would like to find picture though, if you could help that be awesome.
From the upper menu bar (red in my browser), I clicked on "Search", and entered "timing tab".
I looked for threads with an attachment symbol. Found this: https://www.thirdgen.org/forums/atta...-timingtab.jpg
thank you very very much, I was searching "timing bracket" not "tab", again thank you, and looking at the pic I dont think its that far off time if at all, but this helps a bunch!
