Broken Main cap no run time
Old Mar 31, 2009 | 12:32 PM
84 camaro z28's Avatar
Car: 84 camaro z28
Engine: 5.7 carbed
Transmission: turbo 350
My main cap on my crank is cracked on the cery end near the flexplate and i havnt run the engine yet. If i put in a different cap from another engine do i have to line bore it or will i be successful in just doing the replacement. I dont want to have to take it apart cause i just got together but if i have to I guess i will to do it right, just thought id get an opionion from you guys.
Old Mar 31, 2009 | 12:35 PM
jg04222's Avatar
Car: '82 Z-28
Engine: 355
Transmission: TH-400, 8" ATI MRT
Axle/Gears: Moser 9", 4.56's
Re: Broken Main cap no run time
at the bare minimum you will have to have the alignment checked, then determine whether or not it will need to be align honed/bored.
How did the cap break if the engine has no run time on it?
Old Mar 31, 2009 | 12:45 PM
Car: 84 camaro z28
Engine: 5.7 carbed
I have no idea it puzzles me too cause we had it all checked before we assembled. Had the block bored honed clearanced hot tanked. One guy told me that i might not had it aligned when i was torqueing it down but im pertty sure that it was right. For this alignment deal can I do that or does the shop has to do it. I took the cap off from another four bolt main 80's style block so for the Most part it should be could.
Old Mar 31, 2009 | 01:41 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
It will need to be align bored and honed, no question. Doubtful that it cracked when you torqued it down unless you tried to put it on backwards.
Old Mar 31, 2009 | 02:22 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
engine might have been dropped at some point?
I think align honing is good enough isn't it? Either way, the machine shop will know what to do. It's similar to buying a new set of main bearing caps - same procedure.
Old Mar 31, 2009 | 09:34 PM
Car: 84 camaro z28
Engine: 5.7 carbed
Ok I seeing the crack in person now today it its just a hair fracture near the seal not sure if it goes all the way or not. So do I buy a new set of caps or just find another pair from another block?
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
