engine oil problem
Old Apr 1, 2009 | 03:54 PM
tonys91rs's Avatar
Car: 91 Camaro RS
Engine: 305 TPI conversion.
engine oil problem
i have a 305 in an 88 vert that was converted by the previous owner from a tpi to carbed. after cleaning up the engine bay i removed the canister and plugged in the vacumn from the carb. i put a breather on the passenger side valve cover.
i recently discovered that oil is coming up through the dipstick tube and breather. how do i fix this?
Old Apr 1, 2009 | 05:48 PM
QuickStyle's Avatar
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
Re: engine oil problem
you need a pcv valve on the opposite side valve cover that has a breather on it.
db057
Aug 22, 2015 08:17 PM
Navy8125
Aug 21, 2015 09:32 AM
zeitghaist
Aug 18, 2015 07:33 AM
92camaroJoe
Aug 13, 2015 06:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
