Intake Exhaust Crossover Block Off - What Side
Old Apr 1, 2009 | 07:25 PM
85FBTranam's Avatar
Car: 1985 Pontiac Trans Am
Transmission: BW T5, Hurst Short Throw Shifter
Axle/Gears: 3.70 Posi
Does it matter which side (head or intake manifold), the metal exhaust crossover block off plates are installed? Should it be head, block off plate, intake gasket then intake manifold or head, intake gasket, block off plate then intake manifold?
Thanks.
Old Apr 1, 2009 | 09:09 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: Intake Exhaust Crossover Block Off - What Side
You mean restrictor right? You probably dont want to block off the exhaust cross over because that will lead to some drivability issues. Now if your talking about the restrictor then it does matter which side you put it in and is specified in the instructions which applications used them and on which side they were used.
Old Apr 1, 2009 | 10:50 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
If you have headers then it doesn't matter what side has what kind of plate over the crossover holes. If you don't want the exhaust gasses to help warm up the carb then block off both holes.
With factory style exhaust manifolds, it's always been common to have the exhaust heat riser valve on the passenger side manifold. This valve is closed when the exhaust is cold and will open up once it gets warm. With the exhaust closed off or at least restricted, the exhaust gases are forced into the intake crossover. The passenger side head opening is open or restricted and the drivers side head is blocked off or restricted.
It doesn't matter which side of the gasket you put the plate on.
Old Apr 2, 2009 | 03:44 PM
85FBTranam's Avatar
Thanks very much for the responses....it is greatly appreciated!
1992 Trans Am
May 10, 2023 07:19 PM
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
transaero
Aug 31, 2015 01:14 AM
db057
Aug 22, 2015 08:17 PM
