1986 z28 wont start
Old Apr 1, 2009 | 08:31 PM
jtsk's Avatar
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
1986 z28 wont start
Ok, pulled in the drive shut it off and when I got back in it, the car just spins over. No fire what so ever. I have replaced the coil, ignition module, and distributor cap. I verified that there is 12 volts at the wire going in to the distributor also. The motor is a bone stock 305 4bbl. I also swapped the computer and still no fire. I am at a loss. Any help would be greatly appreciated.
thanks,
JS
Well, it turned out to be a bad distributor. We put a new distributor in and it fired right up. Got the idea for the fix from another site, www.hotrodders.com. You might give 'em a look if you can't get what you need here.
thanks, JS
Steven 86IROC-Z
Mar 28, 2026 06:42 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Cleotiz
Jan 6, 2018 08:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Bryan F
Aug 18, 2015 02:28 PM
