383 sbc with brodix track 1 heads question
Old Apr 4, 2009 | 03:10 AM
mcbchild's Avatar
Car: 1984 Firebird SE
Engine: 388 sbc, Brodix Track 1s
Transmission: turbo 350 transmission
Axle/Gears: 4.10 gears
I was wondering if any one would happen to know if the track 1 brodix heads with the 2.08 intake valves have enough piston to valve clearance with a cam with .550 lift? Also the heads have been milled down to 63cc and with -5cc flat top forged pistons.
Old Apr 4, 2009 | 08:01 AM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
Re: 383 sbc with brodix track 1 heads question
Best bet is to mock it all up.
Old Apr 4, 2009 | 11:38 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
it should be alright.. i have a near .600 lift cam with 2.050" intake valves and i have more than enough clearance..
but mock it up to make sure.. its cheap insurance.
Old Apr 4, 2009 | 11:46 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
whats the duration of the cam?
My zero deck block with .041" gasket and 2.05" valve with 230/245 duration .603/.613 cleared just fine. 5cc flat tops as well, 383 motor.
Old Apr 9, 2009 | 12:12 AM
bart91406's Avatar
Car: 91 rs
Engine: 383 290 cam aed carb
Transmission: th350
Axle/Gears: 4.10 ticking time bomb
The amount of lift has absoulutely nothing to do with piston to valve clearnance! NOTHING!
When piston to valve clearance is an issue is when the piston is approaching the top of the cylinder, while the valve is starting to open, as you may guess they are going at eachother. This is nowhere near max lift, by the time the cam gets to max lift the piston is well down the hole, and traveling away from the valve.
Whether your pistons are flat top also has no affect, the only way your piston affects it is the depth and radius of the valve relief, and your description of the piston gives us no idea of this.
Your brand of cylinder heads also gives us no useful info, the only impact the heads have is valve size and how the valves will fit into the radius of the valve relief, and being a 2.08 valve it may or may not clear.
The reason for my post is to inform you the only way know piston to valve clearance is a check. The main variable is cam timing, and the size of the cam is not the only factor, two cams of the same size can open and close at different times. I would also like to point out again, that max lift has nothing to do with piston to valve clearance! Sorry to rant.
theurge
Aug 21, 2015 12:46 PM
86White_T/A305
Aug 17, 2015 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
