Aluminum head rocker arm bolt hole stripped
Old Apr 4, 2009 | 12:22 PM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
I always take my rocker arms off over the winter to avoid weakening the valve springs during storage. I went to put it everything back together today and one of the rocker arm bolt holes in the head is stripped. I went to torque the bolt down on one of my shaft mounted rockers and it wouldn't tighten the threads pulled right out. This is a 7/16-14 hole on aluminum heads. Can I heli coil this safely or should I just take the head off and have a machine shop repair it?
Old Apr 4, 2009 | 01:46 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You should be able to helicoil it if you're confident in your ability to get it in straight.
evilstuie
Jan 9, 2020 08:29 PM
midge54
Dec 27, 2019 04:14 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
