Altanator question...
Old Apr 4, 2009 | 08:33 PM
areonic1's Avatar
Alright, I have an 89 Iroc, 350 in it.
Now,the battery is the red top optima, and all other electrical stuff is stockish.
I have removed the stock ECM, and stockgauge cluster.
The problems im having is, I have to charge the battery to get it going, it will stall as im driving due to no bat power. Other problems too, but these are the obvious.
Now, i read somehwere that the altanator uses the gauge inside te dsh to tell it to turn on? Anyway, would me removing any of these, be causing my alt to not charge the battery?
Old Apr 4, 2009 | 09:07 PM
sgt7n5's Avatar
Car: 83 z-28
Engine: 305 LG4
Re: Altanator question...
the voltage regulator regulates the voltage in the alternators rotor to increasse and decresse the magnetic feild if the reulators broken or not getting a signal there is no magnetic field and no power is being made. for a quick little test just put a meter to the cas and postitive stud should be gettin 14ish v
Galaxie500XL
Oct 1, 2015 01:05 PM
happyhapka
Aug 15, 2015 04:42 PM
ebmiller88
Jan 28, 2002 09:51 AM
KlayBuRn
Car Audio
Aug 30, 2001 12:52 AM
Lotsokids
Carburetors
May 28, 2001 08:42 PM
