Vortec headed 305 against WC T5
Old Apr 8, 2009 | 03:23 PM
oxrabidus's Avatar
Car: 1989 Camaro RS
Engine: 2.8l v6
Transmission: 5 Speed Manual
Axle/Gears: Probably the stock 3.42
im getting an LB9 out of a 89 iroc z i believe has 230hp and 295 ft/lbs...
i also have a set of 305 heads casting number 520 (which is apparently the same as the other 305 vortec heads, no swirl ports...) say i put those heads on stock (no potrting or anything...) along with the stock tpi (with a edelbrock tpi baseplate) would the t5 hold up to it? because i was once told that the heads will be at least a 30hp increase from tpi heads...
the 520 heads are the same as the iron lt1 heads but with regular coolant passages, i want to make sure im not gonna break the trans... i have been told that there are some cars with t5s in the mid to high 12s... but they didnt say what they were making, although i dont intend for it to make enough to get even past high 13s low 14s... but still wanna make sure...
thank you
Old Apr 8, 2009 | 03:25 PM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
Re: Vortec headed 305 against WC T5
you'll be okay...I don't know about getting 30horse out of those heads...but you still should be okay..
Old Apr 8, 2009 | 03:33 PM
oxrabidus's Avatar
Car: 1989 Camaro RS
Engine: 2.8l v6
cool... i was gonna tune it get the edelbrock baseplate, eventually the runners, and lt4 lightweight valves sprigns etc etc and call it a day but i started thinking... the t5 is kinda weak from what i hear...
but its gonna be stock other wise... i wanna make sure i beat my friends 09 stang... its a v6, but they still run low 15s from the factory...
Old Apr 8, 2009 | 03:41 PM
Engine: L98 494hp
t5's are very weak....don't slam shift it...
Old Apr 8, 2009 | 04:54 PM
oxrabidus's Avatar
Car: 1989 Camaro RS
Engine: 2.8l v6
i dont inted to power shift i actually use the clutch... but i want to be able to race it at the track occasionally and have it not break... oh well if it breaks ill have to save and get a tko500...
thank you
Old Apr 8, 2009 | 08:39 PM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
It will work fine as long as you do not power shift it. I ram ny 305 5sp car to mid 13 without it breaking.
Old Apr 8, 2009 | 09:17 PM
oxrabidus's Avatar
Car: 1989 Camaro RS
Engine: 2.8l v6
good to hear that... i found a lt1 cam out of a 95 z28, guy aid its the biggest lt1 cam from the factory... but that and the heads with lt4 valves springs etc and a sdparts tpi base and a nice tune... hopefully mid 14s...
is 9.7 comp safe with iron heads? i was thinking of using the .015 thick head gasket to increase comp... but for now that would satisfy me... my goal of mid 14s...
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
bamaboy0323
Sep 3, 2015 06:07 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
