89 T.P .I.wont start
Old Apr 10, 2009 | 09:42 PM
johnrstuch's Avatar
Car: 89 Trans am GTA
Axle/Gears: not sure
ok so I have this 89 GTA with TPI the engine was running when i pulled
it out to rebuild it. when i reinstalled it, it ran but it was missing real
bad, i think it had a bad injector. the guy i bought it from put a starter
button on the dash because he said the VATS module was bad. so i
pulled the TPI out and put in a carb. later i wanted to reinstsall the TPI.
but i never could get it to start,could someone give me some advice on
where to start on diagnosing the problem.
1. engine cranks over but will not fire up
2. engine has fire
3. not sure about fuel pressure
4. wondering about that VATS module
Last edited by johnrstuch; Apr 10, 2009 at 09:57 PM. Reason: need to add more info
Old Apr 11, 2009 | 08:07 AM
Vader's Avatar
Re: 89 T.P .I.wont start
Verify that it has at least 35 PSIG fuel pressure. Test for injector pulses. If the injectors are not operating, it may be a VATS issue.
VATS Help
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
