Problems starting
Old Apr 11, 2009 | 04:54 PM
Firebird Mess85's Avatar
Car: 85 Firebird & Grand Prix GXP
Engine: LG4 305 (originally 2.8L V6)
Axle/Gears: 10 bolt 3:43 Open Diff.
Problems starting
I'm not sure if it's the starter but figured I'd put a video up to see if any of you have encountered the same noise / problem when starting their car.
The video is of my jumping my Firebird with my Bonneville and just getting clicking noises from the bird.
http://www.youtube.com/watch?v=sgElbNIiRr4
Old Apr 11, 2009 | 05:06 PM
50bmgshooter's Avatar
Re: Problems starting
start by checking your connections. it sounds like a bad connection
Old Apr 11, 2009 | 07:05 PM
What would cause a bad connection all of a sudden when the car hasn't moved?
Old Apr 11, 2009 | 11:42 PM
chas0218's Avatar
Car: 86' IROC
Engine: 388
Transmission: Built 700r4
Axle/Gears: 3.08 non-posi
X2 dont know what could cause it but thats what it sounds like. Most of the time its the terminal on the battery grab the wire and try to turn it on the terminal tighten it if need be or else ur battery could be shot too. What are you jumping it with?
Old Apr 12, 2009 | 12:37 PM
Jumping it with my 2000 Bonneville. Never had a problem before.
Old Apr 12, 2009 | 12:58 PM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
Axle/Gears: open/3.42
Depending on how long it sat it could just be corrosion on your connections . Make sure all connections are clean and tight .
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
92camaroJoe
Aug 13, 2015 06:07 AM
