At 110 I Hit The Wall! Help, Question About The Governor.
Old Apr 14, 2009 | 08:23 PM
DeathMetalTony's Avatar
Car: 2002 GS300 Sport Design
Engine: 3.0L 2JZGE
Transmission: 5-Speed Shiftable Automatic
HI THERE EVERYONE, FIRST OF ALL MY QUESTION IS. ON MY CAR WHEN I DROP IT TO 1ST THN 2ND THEN 3RD BUT AT 3RD GEAR NOT EVEN RED LINEING YET AT 110MPH, I HIT A BRICK WALL. WELL MY CAR STARTS TO PULL BACK OR SO IS THAT THE CAUSE OF THE GOVERNOR OR SOMETHING? THEN ILL SHIFT INTO 4TH AND STILL I CANT GO FASTER THAN 110MPH WHATS MY PROBLEM HERE? RPM'S DONT DROP OR SO.
Old Apr 14, 2009 | 08:31 PM
Stephen's Avatar
Car: 87 GTA
Re: At 110 I Hit The Wall! Help, Question About The Governor.
Yep....Thats the good ole ECM speed override, courtesy of the ignition cutting out, until the speed is reduced. Once the speed is reduced, it kicks right in, right?
BTW....Typing in caps is seen as yelling or emphasis (if only a single word is capitalized). Might I suggest not typing in all caps? Thank you.
Old Apr 14, 2009 | 09:12 PM
Damon's Avatar
It's burned in the chip and based on the tires that originally came on the car from the factory. If your car came with tires with an S spreed rating, as many 3rd gens did back then, they were only rated to 112 MPH. Guess where GM chose to shut the party down on cars with 112 MPH speed rated tires?
Old Apr 14, 2009 | 10:53 PM
Engine: 3.0L 2JZGE
Thanks for the advice on the caps thing, i reah somewhere it hsa to do with a prom or something would that might be right? and if not what is exactly i need to do to fix my issue.
Old Apr 14, 2009 | 10:55 PM
Engine: 3.0L 2JZGE
Thanks for the advice on the caps, is it a prom or something? or what do i need to do exactly to fix my issue.
Old Apr 14, 2009 | 11:19 PM
IROCtheThird's Avatar
Car: '89 IROC-Z
Engine: LSx
Yes its in your prom, you can have a new chip burned and tell who ever burns it to remove the speed limiter.
Stephen's Avatar
Car: 87 GTA
Actually, yes & no.
Yes you could have a custom PROM programmed & get rid of it....$$$
Now, I would suspect your ?TPI? would work the same way, but I'm not 100%, but I see NO reason whjy not. Or you could get rid of it for under $3, or even FREE, if you already have a spre toggle switch laying around.
Originally designed & written on a TBI/T5 car, but a TPI should be using the same VSS, right? If so..... Speed Limiter Bypass
evilstuie
Jan 9, 2020 08:29 PM
billybob6110
Sep 24, 2016 09:50 AM
beastin91rs
Oct 9, 2015 07:38 AM
ydnar417
Sep 23, 2015 05:57 AM
redmaroz
Aug 16, 2015 11:40 PM
