oil restrictors
Old Apr 15, 2009 | 08:53 PM
91 camaro 383's Avatar
Car: 91 Camaro LS1
Axle/Gears: 9" 4.11
oil restrictors
ive got a hopped up 383 stroker motor im getting ready to reasemble. all forged internals roller cam afr comp 210 heads titanium retainers etc. and i was looking into the oil restrictors and lifter galley breathers and so on. i was wondering what you guys thought about them and whether they owuld be right for my application. one more question, when reassembling this motor should i use a windage tray or rocker arm reflectors thanks
Old Apr 15, 2009 | 10:42 PM
birdtojag's Avatar
Car: 87 Firebird, 90 bird coming soon
Engine: 355 Chevy Vortec Heads TPI, LT1 inj
Axle/Gears: 2.77 posi 9-bolt
Re: oil restrictors
Don't have much experience with the oil restricters, but the windage tray and the rocker deflectors are both good. Windage tray helps keep the crank from splashing around the oil in the pan and the rocker deflectors keep the oil on the valve stem tips with the rocker to help keep it lubed. I would do both if you are doing a high horsepower, high RPM engine.
Old Apr 15, 2009 | 11:21 PM
The_Punisher454's Avatar
Car: '74 Firebird, '84 vette
Engine: 454 twin turbo, 350 HSR
Transmission: 4L80E, 700R4
Axle/Gears: 9", Dana36
Re: oil restrictors
dont use restrictors unless you need to. I assume your cam is a hyd roller and if so then definitely not.
thats something you can do when you run a solid cam and full roller rockers, and even then the restrictors are usually a bit too small. I sometimes use them, but I drill'em out a bit.
Stay away from them if your not sure you need them.
Old Apr 16, 2009 | 10:10 AM
Car: 91 Camaro LS1
Axle/Gears: 9" 4.11
Re: oil restrictors
ok thanks alot for the advice. i am just using a hydraulic roller cam but ive got jesel shaft rockers on this setup would that change anything?
jrdturbo
Mar 31, 2016 02:58 PM
skinny z
Oct 5, 2015 06:23 PM
meeklay812
Oct 1, 2015 03:46 PM
Gordonr1973
Sep 29, 2015 11:59 AM
