fuel gauge reads 3/4 at 1/4 full
Old Apr 16, 2009 | 04:11 PM
my90bird's Avatar
Car: 1990 firebird formula
Engine: 5.0 tpi
Transmission: t-5
fuel gauge never worked right ever since I got the car.I pulled the sender out today to see how much gas was in the tank,its was about 1/4 tank and the gauge read 3/4.would the sender be bad or someone took the gauge pin off and put it on wrong?
its a 90 formula 5.0 5 speed
Old Sep 27, 2009 | 03:26 PM
Nitehawk83's Avatar
Car: 91 Z28 Camaro
Engine: 5.0L
Transmission: T5 5-speed
Axle/Gears: 3.08
Re: fuel gauge reads 3/4 at 1/4 full
Bump... I am having a similar problem. My fuel gauge wont read lower than 1/4 tank. If it has a 1/2 tank it will read a 1/2 tank for example, and will decrease as it should but wont go below 1/4. Any suggestions?
Old Sep 27, 2009 | 03:28 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
From what I can tell this is a fairly expensive problem unless you go junkyard diving to get a used sending unit.
I think I remember a new sending unit being $200 or so?
Either way... my gauge will vary as much as 1/4 of a tank depending on whether I'm braking, accelerating, turning, whatever.
Old Sep 29, 2009 | 09:56 AM
vulcanravenxvg's Avatar
Car: 89 RS Camaro
Engine: fuel injected 2.8 6 cyl
Transmission: Automatic
Axle/Gears: Stock crap
our gas gauges and the instruments that send the readings are serial liars. lol. im fairly sure that the gas gauge is about as reliable as trusting a ford. you never ever trust a ford for transportation. nor should you trust the gas gauge. lol I had the same problem in my old camaro... RIP. 89 rs "Jackie"
Old Sep 30, 2009 | 11:47 PM
matthufham's Avatar
Car: 90 z28
Engine: 355 with hsr
Transmission: t56
Axle/Gears: 3.73 posi
mine says 1/4 when it starts running out. i'll be getting aftermarket gauges, and until then i keep it topped off
Ghettobird52
Jul 5, 2024 11:18 PM
midge54
Dec 27, 2019 04:14 PM
justin57
Aug 20, 2015 07:05 PM
86IROC112
Aug 17, 2015 02:00 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
