Jack Problems
Old Apr 17, 2009 | 06:36 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
Jack Problems
i know there is not a proper place for this, but it needs to be somewhere
ANYWAY
i got a hydraulic floor jack, looks like this one,
but its not that brand, but same jack
anyway, its acting all kinds of strange....when you pump it up it only seems to have "pressure" on the handle for 30-40% of the pump, its also slowly leaks down, its full of fluid.
was wonderin if anyone has used something like bars leak hrdraulic stop leak to seal one up or knows about adjusting the "do not adjust" screw on it......its not leakin fluid, and like i said its full, id hate to spend over $100 again on a jack, and im sure not using one of the cheap ones
any ideas guys
Old Apr 17, 2009 | 09:18 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: Jack Problems
Sorry, but it's got a bad seal. Cheap Chinese junk most likely. They never last very long. Unless you can get a rebuild kit for it, it's probably done.
Old Apr 17, 2009 | 10:32 PM
89RS_82Z's Avatar
Re: Jack Problems
bah!!! thats what i thought....i guess i will try that bars leak hyd repair,if it works than cool, if not im out $4
any other ideas
Old Apr 17, 2009 | 10:49 PM
86sdubzzT/A's Avatar
Car: 1986 T/A
Axle/Gears: Stock
Re: Jack Problems
Use jack stands
Sorry...couldnt resist.
I think its done....but at least you get a lil bump. Maybe someone knows a trick. I might try some brake fluid in a last ditch effort.
Old Apr 18, 2009 | 10:06 AM
50bmgshooter's Avatar
Re: Jack Problems
i would save my money and buy a good jack and stands. I use lincon jacks and stands there about 300 for a set. but after 15 years the jack is still in perfict working order. so well worth the investment. also just rember this and think about it when buying a jack and stands YOUR AZZ IS GOING TO BE UNDER THAT CAR AND IF THE JACK OR STAND FAILS WHEN YOU ARE UNDER IT CHANCES ARE YOUR DONE.
so I say spend a little more now and save a life or a lifetime of pain for you or who ever helps you.
Old Apr 18, 2009 | 11:14 AM
Vader's Avatar
Re: Jack Problems
I wouldn't use any additives to the hydraulic oil. You can try to repair the jack. Most likely you will find failing or contaminated seals and O rings.
ALWAYS use jack stands, even with a new jack. The only exception is with a jack which incorporates a mechanical locking device, like some air, frame, and electric scissors jacks.
Old Apr 18, 2009 | 03:14 PM
89RS_82Z's Avatar
Re: Jack Problems
well i got good jack stands, im going as a last chance try an additive, if it dont work o well, go buy a real good one
customblackbird
Aug 15, 2021 10:16 PM
NORTz89
May 20, 2020 03:51 PM
69 Six Pack
Oct 5, 2015 07:51 PM
greenyone
Sep 2, 2015 03:39 PM
Thornburg
Aug 27, 2015 11:34 PM
