intake clearance
Car: 1986 z28
Engine: 350 from 305
Transmission: t5 borg werner
intake clearance
I purchased a 350 w/ edelbrock performer rpm intake. I did some research and found its a good intake for my application, but when I installed the engine I only have about 1.5 to 2 inches to get the air cleaner on with the stock hood. The car is too nice to replace it with an aftermarket, does anyone know a part # or product # that I can use to find the proper air cleaner.
Car: camaro iroc-z
Engine: 355 L98 Corvette engine
Axle/Gears: 3.27 9 bolt borg warner
Re: intake clearance
hello redirocz28
did you get your answer now?
i looking for the same answer because i got the same question after a tpi to carb swap!
i will go for a dual plenum cold air intake but the mounth on the carb from the plenum is 3,5 inch tall.
i will now if i have that clearance with a edelbrock performer rpm and a holley 4160
thanks dennis
thanks dennis
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
one of these
http://www.summitracing.com/search/P...rd=air+cleaner
New2Chevy
Sep 28, 2015 12:35 AM
toronto formula
Sep 10, 2015 07:31 AM
