Code 42 est circuit
Old Apr 19, 2009 | 05:29 PM
v8s10blazer's Avatar
Car: 96 S-10 Blazer
Engine: 355 TBI
Code 42 est circuit
Hey guys,
Im having some trouble with my ignition system. Ive got code 42: electronic spark timing (EST) circuit grounded. The computer isn't controlling the ignition timing because of this. This problem crept up real slow, first it was the occasional misfire then after a couple weeks it would miss going up hills or anything over 1500rpms. Its like a bad wire or something.
Anyways here is what ive done so far:
1. Took 1 year old ignition module to autozone for testing: Passed
2. Checked by pass wire for ground or short: Passed
3. Checked EST wire for ground or short: Passed
4. Checked reference low: Passed
5. Checked reference high: Im not sure, it only had 1Volt. Shouldn't it have 5??
6. Switched out ECM with another
I'm not sure what else to do. Any input would be awesome. Some other info:
16168625 ecm
Accel cap and rotor
msd wires, blaster coil, and 6A controller
TBI 355 mild build
Old Apr 20, 2009 | 07:51 PM
Car: 96 S-10 Blazer
Engine: 355 TBI
Re: Code 42 est circuit
I went ahead and ran a whole new EST wire from the module to the computer and I even tried a new module (different brand too) and still no fix..
Heres the strange part. If i disconnect the by pass wire while the motor is running, it runs really rough like it should with no computer controlled timing. I would think it would run no different since its not getting or thinking its not getting timing information from the module.
$750 L98
Feb 1, 2025 02:25 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
