NEED HELP NOW
Old Apr 20, 2009 | 09:13 PM
84 camaro z28's Avatar
Car: 84 camaro z28
Engine: 5.7 carbed
Transmission: turbo 350
NEED HELP NOW
Okay, I'm trying to get my car running by this friday but im having some issues. Okay the engine is making some ticking noices, and don't get me wrong its not the rockers. One person thinks its pre ignition cause im running pump gas with 10.7 to 1 compression and one person thinks its rod bearings fresh rebuilt 383 no miles on it any help?
Old Apr 21, 2009 | 07:09 AM
Vader's Avatar
Re: NEED HELP NOW
What RPM/load does the noise occur? Can you isolate the source better? Top? Bottom? Front? One side? Does this happen cold, hot, or both?
Old Apr 21, 2009 | 08:39 AM
50bmgshooter's Avatar
Re: NEED HELP NOW
check for exhaust leaks
whats your timing set at 10.5-1 should be no prob on pump gas
I use to run a bbc @12.5-1 on 92
