pushrod and rocker help!!
Old Apr 22, 2009 | 10:35 PM
Camaroman575's Avatar
Car: 1988 Chevy Camaro
Engine: 305 V8
ok sooo i had a tick in my engine( 305 v8 from a 88 camaro).
so i took all the pushrods out and they were all fine. so i put them back in and over tightened the rockers waaaaaay to tight and tried to start my car. then BOOM. so i took them all back out and all of them except a couple are bent pretty bad. so i got new ones and i need to put them in.
1. how to adjust the rockers when everything is back in.
2. what might be damaged from the pushrods being bent.(valves, springs, ect.)
3. best way to install pushrods and rockers and get it them all adjusted again.
i've heard that you tighten the rocker nut till there is resistance on the valve. then start engine with towels to catch the oil. then from back to front tighten each nut a 1/4 turn. idk how to do. never done it before..
HELLP! please
Old Apr 22, 2009 | 10:42 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Re: pushrod and rocker help!!
Do a search there are threads, tech articles here, and on the web.
You really don't need to do it with the engine running.
Here's a couple, read a few before doing adjustment.
http://www.centuryperformance.com/ad...h-spg-149.html
http://cranecams.com/?show=techarticle&id=2
Old Apr 22, 2009 | 10:56 PM
dr.fiero's Avatar
Car: '91 S10 Blazer
Engine: TBI 350
Axle/Gears: 3.73 posi
And do yourself a favour... since you have the covers off, and the pushrods out... Yank your plugs, borrow or buy a leakdown tester. Pump up the cylinders, and see how many valves you just bent (maybe you'll be lucky and it'll be none!).
But I bet you'd rather find out now than after you put it all back together.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
slowsi
Oct 18, 2015 08:49 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
mfp189
Sep 27, 2015 09:25 AM
