HELP! Fuel Pump Humms AFTER CA Smog Repair!
Old Apr 25, 2009 | 12:23 PM
killerklown's Avatar
Car: 1990 Firebird
Engine: 3.1
Did a search, but this is a bit diff in regards to CA SMOG situation...
Just had my 90 firebird (3.1 v6) smog & "E-VAP" repaired. Had a gas leak from the tank gooseneck and top gasket, which both were fixed (i hope) and timing correctly set.
Passed CA smog and fuel pressure (e-vap) test.
While Driving home I noticed a loud constant humming from the rear, not pulsating or changing with engine revs. Drives ok, no probs.
Should I be worried something is wrong? I know these 3gen fuel pumps are noisy, but never had one this loud. Could it be since my fuel pressure was not right before, does this mean its (fuel pump) working the way it should now?
I just don't want to be broken down in the middle of BFE if so.
Thanks for any input regarding this!
- Killerklown
Old Apr 26, 2009 | 04:02 PM
Car: 1990 Firebird
Engine: 3.1
Re: HELP! Fuel Pump Humms AFTER CA Smog Repair!
bump...
any idea if this is bad???
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
