oil pressure/fuel cutoff switch
Old Apr 26, 2009 | 12:57 PM
curacaoz28's Avatar
Car: 1985 Iroc-z28(sold) 1994 camaro z28
Engine: 350lt1
Transmission: 6-speed manual
Axle/Gears: ???
Hi guys ,
I got a 85 tpi, and the connector to the oil pressure sending unit is broken, when I went to fix it I saw that my unit have 2 pins and after searching I found out it is a oil pressure/fuel cutoff switch, but in any wiring diagram I cant find one with 2 pins thay all have one that seems to go to a tan wire, so what is this all about??
Old Apr 26, 2009 | 03:39 PM
Vader's Avatar
Re: oil pressure/fuel cutoff switch
Originally Posted by curacaoz28
Hi guys ,
You were misinformed. The auxiliary oil pressure switch does not shut off the fuel pump in the event oil pressure is lost. It provides a redundant path for fuel pump power in case the relay fails.
The 1985-86-87 models used a different arrangement than later models. There are two switches - One for the gauge or warning lamp on the instrument panel, and one for the fuel pump circuit.
89GTAOz
May 16, 2020 09:31 AM
mddaniel
Sep 8, 2015 05:16 PM
Slush92RS
Sep 2, 2015 08:56 PM
Navy8125
Aug 21, 2015 09:32 AM
355sbcTPI
Aug 19, 2015 04:38 PM
