Smog Pump Removal question
Old Apr 27, 2009 | 10:50 AM
SystemX's Avatar
Car: 1989 Pontiac Trans Am GTA
Engine: 5.7L L98
Axle/Gears: 3.27:1
I'm looking to remove the smog pump from my 89 GTA and I was wondering if I will get a check engine light or a code for not having the connectors plugged into the air valve unit thing. TIA
Old Apr 27, 2009 | 10:56 AM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
Re: Smog Pump Removal question
No. I regularly take mine out and reinstall it for inspection., along with the AIR valve and associated plumbing.
Old Apr 27, 2009 | 11:07 AM
Stephen's Avatar
Car: 87 GTA
A woulda given you the answer, rather than waiting for somebody to see this Post & Reply with the answer.
And no...The ECM could care less about the smog equipment.
Old Apr 27, 2009 | 12:28 PM
SystemX's Avatar
Engine: 5.7L L98
Axle/Gears: 3.27:1
Thanks for the replies. I did a search and the only info I could find with regards to removing the pump was drivability info and nothing about whether or not it would throw a code or check engine light. Thanks again and sorry if I asked a repetetive question.
Frozer!!!
Jan 19, 2024 04:55 PM
italiano67
Dec 11, 2016 09:21 AM
redmaroz
Aug 16, 2015 11:40 PM
3rdgenparts
Aug 8, 2015 07:09 PM
mustangman65_79
Aug 7, 2015 09:55 PM
