Can someone tell me what this part is?
Old Apr 29, 2009 | 01:44 PM
bigmarv666's Avatar
Car: 89 Camaro Converible
Engine: 305 TBI
Can someone tell me what this part is? The threads are broke where the nut stops on the hose end. Thanks
Old Apr 29, 2009 | 02:01 PM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
Re: Can someone tell me what this part is?
That part you have circled is called an A.I.R. tube.....it is an emmisions item that pumps air into the manifolds....you should be able to find someone that has on either on this website, ebay, or local junkyards.....
Old Apr 29, 2009 | 02:06 PM
bigmarv666's Avatar
Engine: 305 TBI
O.K. Thanks I had no idea what that was.
Old Apr 30, 2009 | 01:32 PM
Sparkytfl's Avatar
Car: 85 TA (sold), 88 Corvette, 02 Monte
Which part broke, the part sticking off the manifold, or the removeable part that the hose clamps to?
If you need it for inspection, I think I have spares of both since I bought smog tube headers.
Attached Thumbnails Can someone tell me what this part is?-85transam-044.jpg
Old Apr 30, 2009 | 01:40 PM
bigmarv666's Avatar
Engine: 305 TBI
The threads the nut coming off the hose screws onto on the manifold side. I just need to know if it is going to cause any vacum leaks or other problems. The air seems to be blowing out from where the threads are split and the car runs fine. I just want to make sure it isn't something thats going to cause problems down the road.
Old Apr 30, 2009 | 10:27 PM
BtownZ28's Avatar
Car: 1984 Z28
Engine: 305 LG4
Mine rusted almost completely through at the same point. Good thing they were going into the scrap heap.
Old May 1, 2009 | 05:05 AM
J91's Avatar
J91
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
I have a good set if you need, PM me an e-mail address and I'll send pix...
Old May 1, 2009 | 03:40 PM
Sparkytfl's Avatar
Vacuum leaks no. Nothing like that. The engine itsself doesn't use that tube at all. The only problems I can imagine would be maybe if it's leaking a lot, your catcon won't be as effective and that might clog it up, and maybe with less air going in, your oxygen sensor might not read what it normally would.
I'd just JB Weld the two parts together. There's no reason to ever seperate them. Unless the check valve (the part the hose clamps to) goes bad. Don't know what the chance of that even happening is.
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
Fronzizzle
Aug 9, 2015 01:15 PM
1nastygta
Aug 8, 2015 07:38 PM
