Scoggin Dickey Crate Motor Springs
About 5 months ago i put a scoggin dickey sd360tpi crate motor in my 87 IROC. Everything for the install went reasonably well. Anyway now Ive got 5000 miles on the car and I have a broken valve spring. I read a bunch of posts in the past about the spring problem on this motor and called SD and they said that they had resolved the problem and it was no longer an issue. Obviously it still is. Anyway Ive decided to just replace all the valve springs. What would be a good choice for springs that will hold up. Its got vortec heads with 1.6 rockers.
Transmission: 4L80E/4L80E
They didn't send you a new set of "no problem" springs?
theshackle
Sep 17, 2020 08:26 AM
theshackle
Mar 5, 2017 06:37 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
