WOT SMOKE
Old May 3, 2009 | 12:09 PM
Bobbyz's Avatar
Car: 87 IROC Z "ZZ4"
Engine: 350 "ZZ4"
Transmission: ck performance th400 3000 stall
Axle/Gears: 3:73 10 bolt
WOT SMOKE
Hey all. i have recently noticed that when i punch the gas on my zz4 350 i get a nice amount of smoke from the tail pipes. and it is only when i punch it.
cruising or idling it is fine except for running a tad rich.
also after a night of romping on it i check the oil and notice i am losing some.
i've heard everything from loading up on fuel to valve seals to rings.
i cant tell the color of the smoke yet but if i had to guess i would say blueish
any thoughts?
Old May 4, 2009 | 09:49 AM
90Formula305's Avatar
Car: 1990 Pontiac Firebird Formula
Transmission: 700 R4
Axle/Gears: peg leg
Re: WOT SMOKE
I was going to say maybe it's running rich enough you're getting a lot of carbon build up but if it's blue then it's oil. Pull a spark plug out and take a look.
Old May 4, 2009 | 10:30 AM
Bobbyz's Avatar
Engine: 350 "ZZ4"
Re: WOT SMOKE
Yeah i was afraid of that. i'll pull a plug and take a peak. weather has been Shi**y here.
also i have a pcv valve hooked up running to the back of the carb that would'nt be an issue would it?
Old May 5, 2009 | 07:27 PM
Axle/Gears: peg leg
Re: WOT SMOKE
that I'm not sure about. If it was burning oil then it would do it all the time, you'd be able to smell it too.
Pac J
May 17, 2020 10:44 AM
FormulasOnly
Jul 23, 2018 08:47 AM
86White_T/A305
Mar 6, 2016 01:48 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
Damon
Sep 26, 2015 04:29 PM
