What Is This Vacuum Port On Intake Manifold
Old May 3, 2009 | 08:21 PM
SpeedyGeek's Avatar
Car: 87 Formula
Engine: BluePrint 355 w/ 600cfm Carb
Axle/Gears: New axles, Yukon 3.73 & Eaton Posi
The car...
87 Formula, 350, Edelbrock Performer EPS Intake Manifold, Edelbrock Performer 600 Carburetor, 700R4 Transmission. The car is a rebuild with a new BluePrint crate engine. The original engine was a computer controlled carbureted 305 LG4 engine.
The part in question...
Look at the pictures below. Between the carburetor and the distributor there is a part screwed into the manifold, it is a vacuum port. I don't recall if it was hooked up to anything or not. I have always had a vacuum sound coming from the engine, this may have been it. Anyway if I put my thumb over the hole to close it up the engine idle goes low and rough.
Question...
What is this thing? What is supposed to be hooked up to it? The rest of the engine is together and ready to go.
Old May 3, 2009 | 08:48 PM
Vader's Avatar
Re: What Is This Vacuum Port On Intake Manifold
Yup. That's a massive vacuum leak. Looks like it's time to cap it, then retune the carb. My guess is that it was intended for a PCV valve or power brake booster.
Old May 3, 2009 | 09:40 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
you do have a way with words vader. i am still laughing at that one.
Old May 3, 2009 | 10:14 PM
SpeedyGeek's Avatar
Car: 87 Formula
Currently the brake booster vacuum is going to the rear of the carb through that metal pipe. Does it make any difference where it's hooked up to? The carb or the intake?
Old May 4, 2009 | 12:36 AM
Sparkytfl's Avatar
Car: 85 TA (sold), 88 Corvette, 02 Monte
It goes to the box above the brake booster. I think I deleted the picture I have of it so I can't repost, it's in this thread https://www.thirdgen.org/forums/carb...hind-carb.html
That brake booster should go to that metal tube and the back of the carb, you have it correct.
Old May 13, 2009 | 01:57 PM
SpeedyGeek's Avatar
Car: 87 Formula
Thanks for the replies. I plugged it. Worked great.
Old May 13, 2009 | 10:07 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
That vacuum port normally is connected to a hard line with a short piece of rubber hose to hold it in place. The hard line goes down the back of the engine to the vacuum modulator on the transmission.
If you don't have a modulator or have a manual transmission, just plug it.
deracer
Apr 11, 2016 12:04 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
Dialed_In
Aug 20, 2015 01:45 PM
86IROC112
Aug 17, 2015 02:00 PM
Jake_92RS
Aug 11, 2015 10:39 AM
