power steering ?
Old May 9, 2009 | 01:32 PM
suzukiz400's Avatar
power steering ?
when my car is at idle i have no power steering but once i give it a little gas it kicks in it also does the same thing driving it, its a brand new pump and as far as i can tell the belt is not sliping on the pully, one other thing that i have noticed but not sure if it has anything to do with it is that the seal above the pit man arm in the gear box leaks a little, not sure what to do any help would be great thanks alot
Old May 9, 2009 | 08:12 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: power steering ?
Model year and make would help. So would engine size and VIN code.
Was the pump just changed?
Pitman shaft seals aren't too hard to replace. Years ago, GM used to list a kit in the parts book. IIRC, it's two seals and some hard spacers. The seals can be replaced with the steering gear on the car.
Old May 9, 2009 | 08:36 PM
86sdubzzT/A's Avatar
Car: 1986 T/A
Axle/Gears: Stock
I just pulled a z steering box out of a '91 Camaro if your interested.
Old May 10, 2009 | 01:49 AM
suzukiz400's Avatar
its a 89 camaro had a 305 in it but when i bought the car it was shot so i put a 350 in it, and yes the pump was just changed
Old May 10, 2009 | 10:07 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
I would say there's something wrong with the replacement pump.
Old May 11, 2009 | 12:42 PM
suzukiz400's Avatar
it turns out the pressure valve was in backwards, turned it around and now it works great.
Squeaky8791
Feb 5, 2020 08:29 PM
Vintageracer
Jan 10, 2020 05:33 PM
Chuck84TA
Jul 15, 2016 09:05 PM
evilstuie
Apr 14, 2016 08:52 PM
deracer
Apr 11, 2016 12:04 AM
