cloyes timing cover
Old May 9, 2009 | 04:33 PM
white85transam's Avatar
Car: 85 trans am
Engine: 383 stroker
Transmission: 5 speed
Axle/Gears: 9 bolt rear 3:70
cloyes timing cover
i just got a new 2 piece cloyes timing cover with cam button and as i was reading through the instructions it say you can only use up to a 7 1/2" balancer and the 8" ones hit the bolts. i unfortunatly have a 8". i was thinking of installing the bolts on the center cover and grinding them down for clearance. has any1 had to deal with this?
Old May 9, 2009 | 05:17 PM
Car: 85 trans am
Engine: 383 stroker
Re: cloyes timing cover
the other thing i was looking into was changing the balancer to a 6.75" one but wasnt sure if it would make a difference on the balance of the motor by changing the balancer. now the 6.75" one will still be for a 383/400 sbc which is what my 8" is for. just wasnt sure if the size made a difference.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
I'llrocya
Feb 2, 2016 11:43 PM
NBrehm
Aug 25, 2015 11:49 PM
