Car will not start issue
Old May 10, 2009 | 08:16 AM
Krik's Avatar
Car: 1990 IROC-Z 1LE
Engine: 5.7 TPI
Axle/Gears: G92 3.23
I can spray starter fluid into the intake and it fires right up. Once the spray stops so does the motor. Fuel pressure is 45ish. Injector light shows its not getting a pulse. Changed out the computer and still have the same problem. Anyone have any insite to my problem?
Car is a 1990 IROC with an automatic and 350.
Old May 10, 2009 | 05:47 PM
Oldsmobileman's Avatar
Car: 1991 GTA
Transmission: Stock
Axle/Gears: Stock
Re: Car will not start issue
I think I may have a similar problem, but no one has given me any insight as to what it could possibly be. I have changed relays, fuel pump, fuel filter, coil, cap, rotor, even put a fresh battery in. Fires up, runs then shuts off. If I spray carb cleaner in it will run a little longer, but then runs real rough and shuts down. If I make any headway I will let you know. Mine is a 1991 350 TPI GTA. Howard.
Old May 10, 2009 | 06:26 PM
the gtaman's Avatar
Car: 1989 firebird gta
Engine: sbc 355 hsr 280xfi 58mm tb
Transmission: raptor 700r-4, 2800 stall
check your fuse, also the 4 plugs running to your ignition coil. they will break inside the cover.crank it over ,have someone wiggle those wires.my gta sat for about 3 weeks until i lucked upon the problem,hope this helps .
Old May 10, 2009 | 07:32 PM
johnny090881's Avatar
Car: IROC
Engine: 383
Transmission: T-5 manual transmission
Axle/Gears: 3.45
Try checking the distributor mght be going bad
Old May 15, 2009 | 07:59 PM
Krik's Avatar
Engine: 5.7 TPI
Just to follow up I figured out the problem. #5 injector was shorted out. Measured 0.9 ohms. Changed it out and the beast ROARS again!
midge54
Dec 27, 2019 04:14 PM
Wade787b
Sep 29, 2015 01:15 PM
mizz0313
Aug 12, 2015 06:45 AM
killer777
Aug 8, 2015 02:47 PM
86Base
Aug 8, 2015 01:34 PM
