lifters and pushrods
Old May 12, 2009 | 02:38 PM
linkz761's Avatar
Car: '86 Trans Am
Engine: stout 350
Transmission: automatic
Im peicing my engine back together and came across a few questions...
First, would the pushrods used on a regular set of heads be different length than those used with vortec heads?
Second, i have two sets of lifters in my garage and its been a while sinc eive seen everything... Are lifters for chevy basically the same diameter? B/c i have one set that doesnt slide into the lifter holes...
anyway, any input would be nice...
Old May 12, 2009 | 03:22 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
In general, it's the type of lifter that determines the length of pushrod. Flat tappet lifters use longer pushrods than factory roller lifters. '86 vs. Vortec heads doesn't change that (does change the type of rocker arms, though).
SBC's and BBC's all use the same lifters. If you have some that don't slide into the lifter bores, they aren't stock-diameter Chevy lifters.
Old May 12, 2009 | 07:09 PM
BtownZ28's Avatar
Car: 1984 Z28
Engine: 305 LG4
Re: lifters and pushrods
You could always take some measurements for comparison.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
skinny z
Oct 5, 2015 06:23 PM
mfp189
Sep 27, 2015 09:25 AM
dimented24x7
Sep 6, 2015 03:51 PM
