Alternator sounds like a supercharger and im at 18 volts!!!
Old May 13, 2009 | 08:30 PM
Josh R's Avatar
Car: Iroc
Engine: 350 4-bolt
Transmission: T5 non-W/C
Axle/Gears: 3.27 Open
Ok so the title says it all. My volts are at 18v and my alternator sounds supercharged. Which is pretty neat i suppose.
BUT. I was driving and turned my headlights on and what do you know they don't work anymore. So i guess this means they blew out cause of the 18volts. Well see. Are the Headlights fused???
WHAT DO I DO? So im guessing the alternator is pissed off or something. Its basically a braned new remanufactured one though. I read something online that said something about a voltage regulator or something that controls the volts... maybe that went bad.
If anyone has any insight on what my problem may be please respond soon. I wanna get to the track this weekend but i don't have headlights! THANKS.
Old May 13, 2009 | 09:15 PM
BASSETT IROC 85's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 355
Axle/Gears: 7.5 inch 342
Re: Alternator sounds like a supercharger and im at 18 volts!!!
Time to replace the alternator, the voltage regulator is bad and is internal. The headlights sould be fused with a fuseable link at the starter.
Old May 13, 2009 | 09:59 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Headlights are pretty tough, other lights should blow first. Take the alt. back and have it tested on their machine. Could be a bad connection somewhere but that would be a rare situation.
92firebirdguy
Sep 1, 2016 07:53 AM
sahlomonic
Sep 20, 2015 07:15 PM
1Aauto
Sponsored Vendors
Sep 8, 2015 11:14 AM
Jlanz55
Sep 6, 2015 03:05 PM
Glowsock
Sep 6, 2015 06:40 AM
