unstable idle in gear after warmed up. need help
Old May 13, 2009 | 08:31 PM
kymission's Avatar
Ok,
Here is the deal. the car runs great until warm- once warm it wants stall and idle very very bad at stop lights. I have to place in neutral and give gas to keep running. will start right back up after stall. No problem. I have replaced o2 sensor, IAC valve tonight, pcv hose, new plugs, new wires, new rotor, New rotor cap, New heads, Runs very good except idle at stop under load of gear. I have datalog from aldl No air system anymore, but I don't think that was it cause it just recently started doing this. I trace it back to filling it up with premium gas once a few weeks ago. Can't get it to run correct since. Can someone please help me by looking at my datalog.
oh ya, lo3 tbi 305.
File Type: txt
Old May 15, 2009 | 10:42 PM
kymission's Avatar
Re: unstable idle in gear after warmed up. need help
anyone?
Old May 16, 2009 | 08:46 AM
shanewbenson's Avatar
Car: 1992 RS
Engine: 305 TBI
Transmission: IROC 700R4
I'm also having a similar problem so i would like to know what you find. You should probably start by checking the fuel pressure.
Old May 16, 2009 | 02:29 PM
88firebird2.8L's Avatar
sounds like the maf mass air flow that happend to me be4 and i changed it and i dint stall anymore.or i could be wrong?just tryin to help
specialized
Jun 18, 2022 09:26 AM
jklein337
Sep 19, 2018 06:23 PM
86IROC112
Aug 21, 2015 07:20 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
