zz4 heads question
Old May 13, 2009 | 11:48 PM
mrtater99's Avatar
Car: 89 RS.. 91 1/2ton 1500
Engine: 305 tbi
Transmission: 5 speed manual
zz4 heads question
hello, I bought a set of zz4 heads for the build i'm doing. My question is, I also bought some 1.6 full roller rockers last year, non self alinging. Is there any way that I can use them with these heads? I didn't realize their pushrod holes were so big until after I bought them. The build, so far, consists of, 92 roller block, hyper pistons, .30 over, polished tpi, 58mm t/b, megasquirt v3, LT4 hot cam, scorpion 1.6 rockers, zz4 heads
thanks
mrtater
Old May 14, 2009 | 06:38 AM
Damon's Avatar
Re: zz4 heads question
You're going to need guideplates to use them. ZZ4 heads use self-aligning rockers.
Old May 14, 2009 | 08:28 AM
mrtater99's Avatar
Engine: 305 tbi
All the guide plates I have seen so far are open ended. Is that gonna make a difference on these heads where instead of haveing small slotted or circle holes it's wide open between them?
mrtater
Old May 14, 2009 | 08:55 AM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
sell the rockers and get self aligning ones.
valve guides also rub against the pushrods so there is the problem with the pushrods wearing as a result of that - you need hardened push rods. you dont have that problem with self aligning rockers.
that is what happens when you dont read everything about what you are doing before you do it.
Old May 14, 2009 | 10:40 AM
Damon's Avatar
Yes, that's true- you will need hardened pushrods with guideplates. But the cost of a set of guideplates and hardened sticks is still going to be a lot less than the cost of a set of self-aligning rockers that are quality/performance equivalent to the ones you have now.
Old May 14, 2009 | 10:41 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
If you use stock guide plates and push rods (Corvette) you are ok, they are not hardened and don't need to be.
lt500r55
Sep 1, 2021 01:30 PM
italiano67
Dec 11, 2016 09:21 AM
bamaboy0323
Sep 3, 2015 06:07 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
