max valve lift
Old May 14, 2009 | 05:15 PM
xpbxwrecked1's Avatar
Car: 87 mustang gt 89 camaro
Engine: 302 355 tpi
Transmission: manual
Axle/Gears: 3.55 and 3.42 posi
max valve lift
im lookin at the summit iron heads and they say max .520 lift
when they state this does it mean just the cam lift or the lift after a 1.5 or 1.6 ratio is added?
i have a .443 lift cam and want to put on 1.6 rockers when i put heads on it
thanks
Old May 14, 2009 | 05:23 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
It means the lift at the valve.
Cam lift is typically quoted at the valve with stock rocker arm lift. If your cam is .443", the lift at the valve with 1.6:1 rockers would be .443/1.5*1.6.
Old May 14, 2009 | 05:28 PM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
Re: max valve lift
or .472 if you don't have a calculator in front of ya
db057
Apr 28, 2019 07:45 AM
Jorlain
Oct 8, 2015 01:57 AM
355tpipickup
Sep 13, 2015 11:35 PM
Nick McCardle
Sep 10, 2015 08:36 PM
