cam advice
Old May 16, 2009 | 09:12 PM
Floorman279's Avatar
cam advice
i plan on rebuilding my motor come fall and im trying to gether all my info early. i know im goona replace the tpi with the HSR. maybe edelbrock performer 64cc heads so about 9.6-1 compression or so. also getting an eagle rotating assembly but am not sure what cam i should do. I know im going with a roller hydraulic cam with roller rockers also, but just not sure which cam. kinda leaning towards something Like the XFI but just looking at your guy's thoughts. thanks.
P.S. NEEDS TO BE STREET LEGAL!!!!!!
Old May 17, 2009 | 08:15 AM
chas0218's Avatar
Car: 86' IROC
Engine: 388
Transmission: Built 700r4
Axle/Gears: 3.08 non-posi
Re: cam advice
try this site for your rotating assembly www.pawinc.com by far the best prices i could find and they are quality stuff also. they will even balance the rotating assembly before shipping it. They also sell cams and a large assortment of parts.
Old May 17, 2009 | 10:30 AM
Re: cam advice
actually the eagle may be slightly better. They have everything but the balancer and flexplate, rated up to 500hp and are internally balanced for $599.99. can get dished or flat top pistons
Old May 17, 2009 | 06:49 PM
Re: cam advice
this is the best one i fond so far.
http://www.compperformancegroupstore...Category_Code=
Old May 18, 2009 | 09:18 AM
bubbatwo0_0's Avatar
Car: 87 iroc
Engine: five-seven L98
Axle/Gears: 3.27 aussie
Re: cam advice
First before picking a cam you will need to know the weight of the car, the gear ratio, compresion ratio, rpm range of the intake/carb and the trans. Then summit will help you pick a cam for your application. If you choose a cam by sound rather than perfomance your car will fall out of a tree faster than it will take off.
Old May 18, 2009 | 09:49 AM
Re: cam advice
yea i rougly know what everythings goona be. does anyone have the link for summits "cam selection" thing?
Old May 18, 2009 | 10:41 AM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
Re: cam advice
again depends on weight, gears, etc....also what you want to do with car.....I would call comp cams directly, they can be a big help....
Old May 19, 2009 | 09:35 AM
Re: cam advice
ok i'll do that then. thanks
Reborn756
Sep 4, 2015 03:42 AM
lt1z350
Aug 28, 2015 05:57 AM
neekolzun
Aug 24, 2015 04:59 PM
stalkier
Aug 21, 2015 01:54 AM
Hello, Michael
Aug 20, 2015 03:19 PM
