diy port and polishing
hey i was just needing some help on porting and polishing my heads if any one knows how or has done it them selfs any info would be helpful thank you also any info on doing your own valve job would be nice to thank you
Transmission: 4L80E/4L80E
There is a tech article on the topic linked from the thirdgen.org homepage.
Or,
Google "Head Porting for the Do-It-Yourselfer" (Standard Abrasives guidelines).
Or,
There's a famous thread from 3 or 4 years ago on the topic.
Or,
Or,
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: diy port and polishing
And unless you work at an automotive machine shop, there is no doing your own valve job.
bigjay89gta
Oct 15, 2015 08:04 AM
