new thread, Losing fuel pressure when engine off.
Old May 18, 2009 | 04:21 PM
tpi90rs's Avatar
Car: 87 Formula 350
Engine: 350tpi
Transmission: TH700R4
Axle/Gears: 3.23 limited
I started a new thread because the old one was clustered and people were answering the first post rather than the current problem
SO... BBK AFPR, new diaphragm and I am losing fuel pressure with the engine off. I pinched the fuel return line and pressure holds. Any thoughts?
When the engine is running, it pops like it's running lean when I rev it up. Timing and everything is set, I think it has something to do with the fuel pressure because I am losing pressure with the engine off, but when the engine is running fuel pressure seems fine. Pressure jumps up when the throttle is blipped ect. just like normal.
I'm just trying to see if this is the problem or if anyone else loses pressure like this?
After I get the engine put back together I'll try to datalog it
Old May 18, 2009 | 05:12 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Re: new thread, Losing fuel pressure when engine off.
I am thinking that losing fuel pressure after key off, is not a big issue as we once thought. In an ideal world the fuel pressure would stay up forever, and never drop. The main thing is that the fuel pressure stays up while the engine is running with no fluncuations. and inceases a little (4 to 8 psi)at WOT.
Old May 18, 2009 | 06:02 PM
tpi90rs's Avatar
Car: 87 Formula 350
Engine: 350tpi
alright, I'm going to bolt everything back up then, and try to datalog.
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
