Rebiulding a 350, should I replace the rings?
Old May 18, 2009 | 06:47 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
This motor is out of my boat. The block is cracked from freezing over last Winter. The engine was run a many minutes with the block cracked. It is amazing how much gray milkshake sledge was indie the engine, maybe 12 quarts or more!!!!
I have the entire engine broken down. I guess this is wise to install new rings.
Old May 18, 2009 | 09:21 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: Rebiulding a 350, should I replace the rings?
I don't understand what you're asking. Are you replacing the block and installing the old rotating assembly into it?
Old May 19, 2009 | 05:37 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Whenever you tear down an engine you should replace the wear parts. You'll never get them in in exactly the same position as you took them out.
Besides, they're cheap.
Frozer!!!
Jan 19, 2024 04:55 PM
hectre13
Dec 11, 2023 08:14 AM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
BBSDesigns
Aug 11, 2015 07:39 PM
