Mechanical Fuel Pump or Electric?
Old May 19, 2009 | 11:44 AM
DyingYoung138's Avatar
Car: '86 Trans Am
Engine: 305 H.O.
So I'm starting to build my 350 (010 cast number bored .040 over) from an early to mid 70's car. I'm planning on pushing this thing to borderline 400 horses if not more if it can fit within my budget.
At the moment, I'm running a 305HO Edelbrock 600 4bbl and I still have my electric fuel pump in the tank. My concern is, with this block more than likely having the mechanical fuel pump spot on the side, what should I do?
Old May 19, 2009 | 01:00 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Mechanical Fuel Pump or Electric?
Summit and others sell a chrome block-off plate for like $10, if that's what you're after.
Old May 19, 2009 | 05:25 PM
Car: '86 Trans Am
Engine: 305 H.O.
Alright, that's nice to know. Is it better to go that route or revert to a mechanical pump?
Old May 20, 2009 | 11:41 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
If your current setup is running fine without any hassles, then keep using it.
Old May 20, 2009 | 03:20 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
one upside I see to having an electric pump: no worry of wiping out a motor because the fuel pump let go and leaked gas into the oil.
one upside to a mechanical pump: don't need to drop your rear end and exhaust to change a bad pump.
I personally recommend sticking with the electric pump if its in good working shape and grabbing a block off plate for the motor. The stock pump should flow plenty for a carb'd setup.
RazorN8
Jan 7, 2022 11:44 AM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
gta90
Sep 15, 2015 04:00 PM
justin57
Aug 20, 2015 07:05 PM
