What's Your Best Guess
Old May 19, 2009 | 02:40 PM
one2burn's Avatar
ECM/or chip - Ing. Coil - Pick Up Coil in the Dist.
If you had to make a guess a on one of these over the others going dead after getting to normal running temp. and restarting cold no problem which would it be.
Old May 19, 2009 | 03:15 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: What's Your Best Guess
I'm also going to guess at what you're trying to ask.......I would say pick-up coil in the distributor.
Old May 19, 2009 | 04:13 PM
one2burn's Avatar
I think you might be right, there cheap but a little work to put in but I'm buying one today and will let you know, thanks George.
Old May 19, 2009 | 04:20 PM
wanta427's Avatar
Car: 1991 Z-28
Engine: 350 L98 al head Stealth Ram
Axle/Gears: 3.42 LS1 brakes
Test it hot and cold . When mine died it ran perfectly for 10 minutes then you had to wait for it to cool down . I changed the module first because it was rolling the dice ,module or pickup coil . Then when it still did it I tested the pickup coil - good cold ,bad hot . So now I've got a spare module .
Old May 19, 2009 | 04:37 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
Years ago I had a problem very similar on my car. It would start cold, run fine until about 15 mins later and stop. Once cool again it would start...
Ended up it was a bad chip...
Old May 19, 2009 | 04:50 PM
one2burn's Avatar
Hi I tested the module's I also have a spare now. Thanks for the help.
Old May 19, 2009 | 04:57 PM
one2burn's Avatar
Ok now your the one that has my attention for sure I got this car with a start up run ok but untill acc. it would bog out it event. got worse to a no start then I changed out the ECM and would start right up now only dies off after hot and Im wondering if I do have the chip prob. no codes etc. tried new coil a while back not the answer and module good and fuel psi fine thanks for the answer I was realy looking to see if that was a common or not even prob. but now you cant find a new stock chip and I want to drop one in if I do it not mess around with programing thanks again, George.
Old May 20, 2009 | 09:46 AM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
I did the same thing. I changed my coil w/ no result, then my ECM w/ no result... Then I put another chip in and it was fine.
What setup is your car? 305/350? TPI? MAF car? AT? You can probably find someone w/ a chip for you to try...
Linson
Oct 24, 2025 02:00 PM
Fanatic1074
Oct 3, 2022 05:57 AM
Ed1LE
Sep 30, 2018 09:14 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
mfp189
Sep 27, 2015 09:25 AM
