High Idle and Code 35. Any suggestions?
Old May 19, 2009 | 02:53 PM
mikenj73's Avatar
Car: 1991 RS Convertible
Engine: 3.1L V6
Transmission: Automatic
I have a 1991 3.1L RS. Recently I removed the plenum and replaced the gaskets. After re-installing the plenum, im getting a slightly higher idle and code 35 (IAC Valve). How can I check the IAC before replacing it? I am running with no thermostat right now, could that be the problem? What else could be causing the high idle and the code 35? Thanks in advance.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
db057
Sep 4, 2015 07:57 AM
mizz0313
Aug 12, 2015 06:45 AM
