overtightening rockers
Old May 20, 2009 | 03:02 AM
johnny89345's Avatar
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
what are some symptoms of sllightly overtightinging rock arms
Old May 20, 2009 | 09:15 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: overtightening rockers
If they're slightly over tightened after the point of proper adjustment, the engine would run rough at worst.
If they've been screwed down all the way, the engine won't run because the valves would never close.
Old May 20, 2009 | 11:13 AM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
Backfiring, if they are too tight, not to mention if it is on a new flat tappet hydraulic, you WILL destroy the cam and lifters if not taken care of quickly!
Old May 20, 2009 | 11:24 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
correct adjustment of regular hydraulic lifters allows for anywhere between at least 90 degrees and 360+ degrees past zero lash.
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
New2Chevy
Sep 28, 2015 12:35 AM
Billyadams
Sep 22, 2015 08:25 AM
ericjon262
Sep 11, 2015 06:07 PM
