hood wont pop
Old May 22, 2009 | 11:17 AM
89IROCK's Avatar
Car: 89 Iroc-z
Engine: 355, Mini Ram
Transmission: 700R4, 3000 stall
Axle/Gears: BW 9 bolt, 4.11's
hood wont pop
So i tired to pop the hood today nothing happened. I look under the front bumper to look for the cable and it was not broken. It was just discontented from the lock, how can i get my hood to open now?
Old May 22, 2009 | 01:58 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Get ahold of the latch some way or another and pop it.
Old May 22, 2009 | 01:59 PM
kkingsrulee's Avatar
Car: 1990 Camaro RS
Engine: V8 305 TBI
Transmission: W/C T5
Axle/Gears: 3.08
Re: hood wont pop
With my car I sometimes have to smack the front tip of the hood a little bit for it to pop, try just thrusting your palm at it with a bit of force.
Old May 22, 2009 | 02:15 PM
89IROCK's Avatar
Car: 89 Iroc-z
Re: hood wont pop
i will mess with it later with weekend. thanks for idea's
Old Jun 4, 2009 | 01:45 PM
88gta_hiflyer's Avatar
Car: 1988 GTA
Engine: 305 tpi (LB9)
Transmission: WC T-5
Axle/Gears: 3.45 posi
Re: hood wont pop
This happened on my 88 GTA. I was able to push down on the front center of the hood right above the latch and get it to pop that way. You may have to do it several times. It worked best when I pushed it down fast then immediately let go.
Old Jun 4, 2009 | 02:46 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: hood wont pop
The latch bar on the hood is binding in the latch assembly on the bumper.
To get it to pop have someone pull the cable while you tap/knock/bang on the hood near the latch. If that doesnt work, grab the hood near the headlight bucketse and shake it from side to side and up and down. Something will dislodge it.
You'll need to lube the latch assembly, if that doesn't work, loosen either of the bolts on the latch bar on the hood itself just a little, and tap it with a wrench and knock it to either side. One direction you knock the latch bar is going to make it easier to open, the otehr direction will make it harder to open. Trial and error. Keep tapping it around until it opens the easiest.
And when I say loosen one of the bolts, just loosen it up enough that if you hit the bar with a wrench it moves less than a 16th of a inch. We're talking small adjustments.
Old Jun 4, 2009 | 02:49 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: hood wont pop
hep, push down, have your assistant pull and hold, then start jiggling. Your assistant should find it easier to pull it all the way if you're pushing down first. Better you jiggle the hood than your assistant.
Old Jun 4, 2009 | 05:30 PM
Klewis89RS's Avatar
Car: 86 IROC, 90 F-250
Engine: LB9, 460
Transmission: 700R4, C6
Re: hood wont pop
Just smack it really hard, that works with mine.
Old Jun 4, 2009 | 07:09 PM
five7kid's Avatar
Is everyone missing what he said originally????
Originally Posted by 89IROCK
... the cable ...was ... discontented from the lock...
I'm assuming that means the hood release cable is disconnected from the latch mechanism.
Old Jun 4, 2009 | 09:36 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: hood wont pop
i also caught that . get car in the air , remove plastic ducts , should be able to see & open latch . maybe time for a new cable . good luck .
Old Jun 5, 2009 | 01:05 AM
aweTastic's Avatar
Car: 1989 Camaro IROC-Z28
Engine: Rebuilt 350TPI (see sig)
Transmission: is being replaced...
Axle/Gears: 20 year old G92 Borg-Warner 3.45
Re: hood wont pop
My hood has this issue I have to have someone pull up on the hood when I pull the lever because the spring is off and cant adjust it =/
Old Jun 5, 2009 | 08:17 AM
Car: 1992 Camaro RS
Re: hood wont pop
The spring isnt the problem. It's the latch and latch bar that are the problem.
Old Jun 5, 2009 | 10:18 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: hood wont pop
The latches do tend to move down over time. Thank GM they're adjustable.
Old Jun 5, 2009 | 10:30 AM
91RS_Charlotte's Avatar
Car: 1991 Camaro RS
Axle/Gears: 3.42 Std
Re: hood wont pop
I had this problem for years on my car. It was always one of those things I meant to fix but never did. As mentioned, pushing/pulling on the hood near one of the headlights broght it up quickly so it wasn't a problem. A while back I finally got around to looking into it. After fiddling around with the latch placement needlessly, a quick shot of WD40 solved the problem. I came back and did a more permanent lube job on it and it works great.
Old Jun 5, 2009 | 11:57 AM
hot92RS's Avatar
Car: 92 Z-28
Transmission: THM700R4
Re: hood wont pop
When that happens to my Z, like the others, I just tap the hood in a certain spot and it opens up. Thanks for the info, though. I thought it was my spring also. I will lube and also do the adjustments called for by Infernal
Old Jun 5, 2009 | 12:41 PM
five7kid's Avatar
People, you aren't paying attention!
He pulls the hood release, and nothing happens because the cable on the other end isn't connected to the hood latch!!!!
Old Jun 5, 2009 | 03:42 PM
hot92RS's Avatar
Car: 92 Z-28
Re: hood wont pop
ur right. We kind of hijacked his thread, but the info helps.
Old Jun 5, 2009 | 04:49 PM
89IROCK's Avatar
Car: 89 Iroc-z
Re: hood wont pop
yeah it was the release cable was disconnected from the latch mechanism. i just pulled the cable around the latch and had someone else pulled the release handle at the same time.
thanks for the ideas!
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
mr z28
Exterior Parts for Sale
Dec 14, 2015 05:14 PM
IROCTheHouse
Oct 26, 2015 02:35 PM
RS Reaper
Sep 27, 2015 07:04 PM
Lmancha96
Sep 25, 2015 08:11 PM
