Do I have a wrong flywheel or starter?
Old May 24, 2009 | 07:12 PM
drumminfoolz's Avatar
Car: 1985 Trans Am
Engine: 360
I have a Pioneer fra-100 flywheel which is a 168 tooth flywheel. I also bought a new starter with a staggered bolt pattern which is for 168 tooth flywheel. When I put the starter on, I had to shim it to .020" for it to start fine. It did one or two times, then I had to shim it to .060". Same thing with that, then I had to shim it to .100", then .140". Before I kept shimming it each time, it grinded. So why do I have to keep shimming it? What's the problem?
I put half shims on the outboard side.
gta892000
Aug 11, 2019 11:16 AM
Dyno Don
Jan 24, 2016 08:24 AM
sahlomonic
Sep 20, 2015 07:15 PM
Nick McCardle
Sep 10, 2015 08:36 PM
