92 rs ???
Old May 24, 2009 | 08:57 PM
1stgenSS's Avatar
92 rs ???
can't get a signal to fuel pump royal pain to change pump but haven't confirmed pump bad yet ... checked most everything relay; no fuse???; ... car was in a wreck and airbag deployed does that reguire computer reset???thanks in advance pulling hair out
Old May 24, 2009 | 09:44 PM
AkitaMan's Avatar
Car: 1991 Flaming birdie
Engine: lo3-305 tbi
Axle/Gears: stock
Re: 92 rs ???
There is a 20 amp fuse in its own little case near the battery, it is for the fuel pump and relay. Check there first. Then pull the ecm and check that it is sending power to the relay, it is pin # 1 on the ecm. Then check for power at the relay, it is the one with the thick orange wire going to it. If you have to, wire a hot wire up from the battery to the fuel pump and see if it will run, it will take a few cranks, because it wont prime the way it should. But it will run that way. Normally its just the fuse near the battery.
Old May 26, 2009 | 08:14 AM
1stgenSS's Avatar
Re: 92 rs ???
thanks will check all
