Couple of little issues;NEED ADVICE
Old May 24, 2009 | 09:13 PM
AkitaMan's Avatar
Car: 1991 Flaming birdie
Engine: lo3-305 tbi
Axle/Gears: stock
Hey guys. I was tinkering around with the bird today,(305 tbi) and I took the Air cleaner off while it was running to see how the tbi was doing. I noticed the fuel was spraying kinda funny. It would spray strong and then kinda sputter, both sides at the same time. The idle was also fluctuating some. Well I got a ses light the other day and decided to pull the codes, what I got was a 15, and a 23. 15;Low temp indicated at coolant sensor, 23. Low temp at at manifold air temp sensor or tps error. Here is the question. Would either of these cause the way the tbi was acting? And how do I test to determine what needs replaced or worked on? Thanks alot guys, you have already saved my butt once with this car!
Old May 24, 2009 | 10:40 PM
AkitaMan's Avatar
Engine: lo3-305 tbi
Axle/Gears: stock
Re: Couple of little issues;NEED ADVICE
mods, please delete this post, The more I look at it, the more I realize it should be in ecm/dfi. Thanks, I will repost it there.
neekolzun
Aug 24, 2015 04:59 PM
justin57
Aug 20, 2015 07:05 PM
ezobens
Aug 19, 2015 10:29 PM
jharrison5
Aug 19, 2015 05:53 PM
jbd1969
Aug 17, 2015 07:06 PM
