Valve adjustment hydraulic roller
Car: 1985 IROC
Engine: lb9
Transmission: 700R4 B&M shiftkit
Axle/Gears: 3.42s
I built a vortec 350 for the 85 iroc. I adjusted the valves with the motor out of the car. When i adjusted them, i tightened the rocker nuts while turning the pushrod until i felt some tension build then i proceeded another 1/2 turn. When i fired it up for the first time, it fired instantly and ran smooth. Do i need to readjust the valves after its supplied a sufficient amount of oil to all parts of the engine?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Valve adjustment hydraulic roller
That 1/2 turn past zero lash is the required preload. That's all the adjustment they require. If they need additional adjustment, something is wrong.
ambainb
Apr 25, 2016 09:21 PM
86CamaroDan
Sep 29, 2015 10:08 PM
gixxer92
Sep 1, 2015 04:32 PM
