Wiper Motor/Fluid Pump Question
Car: 84 Z28, 68K Miles
Engine: 10.5 Compression 350
Axle/Gears: 3.83
I have torn my car down to nothing, so eliminate unneded wiring, tuck the rest, and all around restore metal/carpeting/sound dampening and so on.
The firewall is now mostly bare, but the washer fluid/pump combo thing is an eyesore! are there any later model 3rd gens that use a separate pump in the fluid reservoir? or do 4th gens do so? Either way, is it a direct swap? besides the connector itself, would the wiring remaint he same? it's a pulsed unit. It has a 3 wire connector and a 2 wire connector. I assume 3 wire for wiper speed and 2 wire for pump on/off?
the pump/motor is broken as it sits, so I need to replace it either way and would like to take the opportunity to update something that drives me nuts
Thanks for any input
--Oliver
--Oliver
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Wiper Motor/Fluid Pump Question
i have seen 4th gen tanks/pumps installed . they are hidden in front of radiator . try a search on 4th gen washer tank . good luck .
Axle/Gears: 3.83
What about the wiper motor? can I use a 4th gen one of those? Will it work with 3rd gen collumn switch for delay?
