car wont crank
Old May 30, 2009 | 10:24 AM
wesrams1's Avatar
Car: 1992 Camaro RS
Engine: 350 .060 over
Transmission: stock
Axle/Gears: stock for now
car wont crank
My camaro has been having some problems and has been making weird grinding noises whenever i try to start it. i think the fly wheel is going out. but whenever i tried to start my car last night it wouldnt even crank. every time i turned the key from acc to start the fan stopped spinning and it wouldnt even start to turn over. could this be a starter motor problem?
Old Jun 1, 2009 | 02:13 AM
Jeff91RS's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: World Class T-5
Axle/Gears: 3.27 9-Bolt LSD
Re: car wont crank
Could be a bad starter or a broken wire going to it. If you the starter intermitantly cranks its most likely the starter solenoid, which you can replace separate from starter.
Reborn756
Sep 4, 2015 03:42 AM
TheExaminer
Aug 26, 2015 04:59 PM
Thirim
Aug 13, 2015 03:09 PM
mizz0313
Aug 12, 2015 06:45 AM
gwade12
Aug 8, 2015 08:17 AM
