MAF delete?
Old Jun 1, 2009 | 10:09 PM
Black Z28's Avatar
Car: '88 Iroc-Z z28 Camaro
Engine: Carb 355
Transmission: t5 5-speed
Axle/Gears: 4.11
MAF delete?
I got an 88 Iroc and im always seeing other high year Iroc's with a deleted maf sensor, how is this possible? wat do i need to do to accomplish this? should I do this? Thanks for all the help
Old Jun 2, 2009 | 01:14 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: MAF delete?
85-89 TPI cars use a MAF sensor. 90-92 TPI cars use a MAP sensor mounted on the side of the plenum, not a MAF sensor. You're probably seeing 90-92 TPI cars, right?
You can convert your system to a 90-92 style by following the tech article on this website.
Old Jun 2, 2009 | 07:12 AM
Black Z28's Avatar
Engine: Carb 355
Axle/Gears: 4.11
Re: MAF delete?
would this be a way to go or should i jus leave it the way it is? thanks for the help
Old Jun 2, 2009 | 08:02 AM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
Re: MAF delete?
It really depends on your situation. Do you want to get rid of the MAF for looks, or for tuning reasons?
Swapping to the 90-92 speed density setups can be expensive.
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
Zell1luk
Sep 29, 2015 10:36 AM
